Gibson 490R and 498T pickups.
I've just replaced them in my '93 Les Paul Standard. They are the factory fitted PUs so single conductor and braid. Connections were unsolder and not cut so cable length is still as per the factory fit. Long leg and complete with screws and springs.
20+ years of use so a few very small scratches on the covers as you'd expect.
Had a multimeter across them so resistance is 13.62Kohms for the 498T and 7.77Kohms for the 490R.
£40 each or £70 for the pair. I'll pick up the P&P if you're in the UK.
http://i12.photobucket.com/albums/a226/Rowby1/Pickups/PU1_zpsmxd5gtbs.jpg
http://i12.photobucket.com/albums/a226/Rowby1/Pickups/PU2_zpsrgwibpko.jpg
http://i12.photobucket.com/albums/a226/Rowby1/Pickups/PU4_zps9yhbson8.jpg
