Double strap buttons - why?
TinLipTinLip Frets: 368
I have an Ampeg Dan Armstrong and it has two strap buttons on the bottom of the body...but why?
Neither of them are in the centre which makes choosing a strap  button a bit tricky as it makes my normal strap length too long or too short.
Any idea why it would have 2 buttons? Am I missing something fundamental?
  • lloydlloyd Frets: 5774
    Balance better when you lean them up against a wall?
    Manchester based original indie band Random White:
    https://www.facebook.com/RandomWhite
    https://twitter.com/randomwhite1
  • So it balances better when you lean it against the amp or wall.
  • CirrusCirrus Frets: 8503
    Use both, swing guitar round body like rotor blades of heavy metal death.
  • RolandRoland Frets: 8860
    edited May 2015
    This.  It was a selling feature before guitar stands became popular
  • GuitarZeroGuitarZero Frets: 254
    edited May 2015
    Tom Anderson uses two strap buttons on his guitars.
  • You just wanted to show off that you have a Dan Armstrong Plexi didn't you? I'm on to you!
  • GassageGassage Frets: 31255
    Ok, if you use the bottom one, it's actually more comfy, as it kind of cants the guitar into your body.
  • TinLipTinLip Frets: 368
    Secretly, yes ;)
    Good point @Gassage, never thought of that. I've been using the top button but might have to just get a dedicated strap for it and leave it a bit longer.
    I doubt I'll leave it balanced on the buttons against an amp or the wall though.
  • frankusfrankus Frets: 4719
    in the 60s before putting your balls between the D and G strings and strumming yourself to ecstasy it was considered polite to play with the double strap buttons for a few seconds first.
    Well that's me set for the weekend then...
    It was like an 'AHA!' moment when I switched to the bottom button on my Andy
  • ICBMICBM Frets: 73158
    You're in good company!
    Personally I found it still felt odd on mine, I didn't like the way the guitar felt like it was trying to tip over. I didn't really like the top one either! It's a shame, since apart from it being the best-sounding Strat I've ever played and having the volume control in a more sensible position than a Fender, I didn't really like much about it… the neck was a bit too thick, it was *really* heavy (no-one weighed guitars in those days, but I would say between 10 and 11lbs from what I know now), and I didn't like the three mini-switches, although I later changed the pickguard for one with a lever switch. I still sometimes miss it a bit for some reason though! It was a particularly nice Lake Placid Blue, which makes up for a lot :).
    Ahh.. I've always wondered why the Schecter PT I had came with 2 strap buttons. I thought it was so you could have a choice of how the guitar balanced on the strap, never even imagined it was for making it stand upright.
    It's actually to kid you that it will stand upright. In practice it's very little more stable than a single one - the buttons are far too close together for it to really work - and I certainly wouldn't trust it anywhere other than a room no-one was going to be in.
    I would say it's a solution looking for a problem, and the wrong solution at that...
  • GuyBodenGuyBoden Frets: 790
    Yes, I've put strap buttons higher on the guitar body, yes, it gives a different balance, I found that it was especially good for neck heavy guitars.
  • koneguitaristkoneguitarist Frets: 4225
    Always worked fine for me, it's probably, the distance between the buttons and strap used that makes the difference for me. http://i74.photobucket.com/albums/i278/bargoedboy/cd3051ee-0c31-4815-bd63-1fe6ad35144a_zps8693adad.jpg
  • SassafrasSassafras Frets: 30322
    I'd cut another hole in the strap and use both buttons.
  • octatonicoctatonic Frets: 34008
    ICBM said:
    Tom Anderson started doing it when he worked for Schecter.
    When he moved to his own company he kept doing it.
    I asked him why he did it a few years ago and he said he didn't want to carry a stand with him when he gigged and having two points on the ground gave the guitar stability when lent on an amp.
    Depends what you mean by "stability", I suppose. To me, something which is "stable" when left carefully by itself, thus giving an impression of security, but will still get knocked over by the slightest push because the "base" of the "stand" is only about four or five inches wide and the weight of the guitar overhangs it, is actually *unstable* and an accident waiting to happen.
    Not to mention it becomes even more unstable if you run the cable through the strap so the two buttons don't always rest tightly on the ground...
    Just a bad idea. The only reason I didn't change my Schecter to a single button is because it would have involved a couple of unsightly holes in the body.
