As its a guitar tuner issue I felt it was appropriate to post in the guitar section. Hope that's ok??..
Anyhow here's the issue I want to try the other tuning modes so I select the mode with the button on the left then I wait a few seconds and the mode for example 'B' flashes one would assume it's ready to tune in 'B' but when I pluck the string the needle shows the E string is in tune but it's tuned to standard E tuning???? And not the drop mode I selected. It's the same through out doesn't mater which mode o select it shows it is in tune to E mode??? Is it faulty?
The drop tuning settings only relate to the polyphonic tuning mode. Whatever you've got it set to, plucking a single string (which is what it sounds like you're doing) will send it in to chromatic mode, which will act like a regular tuner- telling you what note it can "hear" and whether it's in tune or not.
If you haven't already, RTFM:
http://www.tcelectronic.com/media/218185/tc_electronic_polytune_manual_english.pdf
Hey man thanks for the 1st part of your
Reply, It deserves a 'wisdom'
Unfortunately the 'RTFM' comment means you get 'SWEET FA'
BTW Brought this second hand with no manual or box and I did read the PDF just didn't find it clear hence the question.
