Also bear in mind that you can't blend the pickups using the volume knobs like you can on a 2-pickup one, the bridge/middle sound is controlled only by the bridge controls.
I like them. I don't find the third pickup gets in the way - and I *do* find the middle pickup on a Strat does if it has raised polepieces - I think the arched top puts the strings higher relative to the body and keeps my hand more away from it.
I agree that out of phase sound is a tad odd compared to what you'd expect.
The 50s LPC look is one I've always liled though. Typically the Jimmy Page model has altered wiring so you get a wider palette of sounds.
You can if you fit the blend/ toggle switch as fitted to the Kirk SG
The ability to blend the middle pickup makes a major difference.
I nearly bought one in a pawn shop a few years ago.
T'was £80.
Shame it was fucked. Completely.
I doubt even a combined effort of all the luthiers in Britain could have got it back to a decent standard.
The neck was twisted, and the 'board was lifting, the body was cracked (more than paint) and the electrics were knackered. I haven't done justice to how bad it was.
Trading feedback here
