Pickup suggestions please (type)
axisusaxisus Frets: 28337
I may get cracking on my guitar build again. It's basically a tele of some kind. I'm wondering what would be an interesting pickup configuration. Here's what I don't want:
3 single coils (I have a great strat)
2 HBs (I have a great LP)
P-rails (have them already)
probably not trad tele (have one somewhere)
~So I'm thinking maybe P90s, mini humbuckers or something else??? I've never had a p90, so I'm thinking maybe one of those at the neck.
What would you go for?
    Sustainer? :)
  • MegiiMegii Frets: 1670
    edited May 2015
    I have a guitar I fitted one of these to in the neck position - was a bit of a gamble ordering it I suppose, but it worked out well, and in my opinion a really great pickup, and something a bit different:
  • Adam_MDAdam_MD Frets: 3420
    If you've never had p90s then that's what I'd go for a good p90 makes a truly glorious noise. My next tele build is going to be a double bound 2 x p90 affair and might end up with a bigsby.
  • stickyfiddlestickyfiddle Frets: 27003
    Filtertrons, or some slant on that theme?
    If you can live with the routing I would go Jazzmaster pickups. Definitely the nicest single coil sound there is (in my opinion of course)
    Second choice would be Jag pickups
  • Oil city alligator 90 for p90 in a tele pickup!
    HB sized p90s.
  • HAL9000HAL9000 Frets: 9673
    P90 neck, splitable HB bridge.
  • steamabacussteamabacus Frets: 1265
    I would stick with a tele bridge pickup (very different to a strat) with something different in the neck - mini humbucker. P90, one of Oil City's Cow-Tron humbuckers maybe?
  • I would stick with a tele bridge pickup (very different to a strat) with something different in the neck - mini humbucker. P90, one of Oil City's Cow-Tron humbuckers maybe?
    Yeah that cowtron is nothing like any other humbucker I've used.
  • ChalkyChalky Frets: 6811
    Sweet P90 neck plus a humbucker bridge offering the choice between raging hot humbucker and spitting wiry bridge. Hence wisdom to @HAL9000...
  • thomasw88thomasw88 Frets: 2325
    irongear alchemist in the neck and irongear blues engine in bridge. Sounds fantastic
  • ICBMICBM Frets: 72352
    Rickenbacker.
    Pretty different from any other single coil. "Toasters" are medium-output Alnico pickups, "High Gains" are high output ceramics.
    They would definitely go well with a traditional ash/maple Tele construction, or you could do a semi-hollow more like a real Rick...
  • GuitarZeroGuitarZero Frets: 254
    Teles with Filtertrons sound great.
  • p90foolp90fool Frets: 31590
    Gold Foils would give you something you don't already have.
  • rprrpr Frets: 310
    Charlie christian for deep and mellow
    Afore mentioned gold foil for bright and gnarly
    or maybe some mix of the two?
  • RockerRocker Frets: 4983
    Piezo bridge. You get "acoustic" sounds into your pa if you use a stereo socket. @ICBM or others will advise on models....
    Nil Satis Nisi Optimum
  • mr_airmr_air Frets: 24
    I say p90s as others have. Or a combination of p90 and some other kind of pickup.
  • OilCityPickupsOilCityPickups Frets: 10431
    I would second all those who have said a P90 ... but I would put that in the neck, and a really pokey, high output Tele pickup in the bridge ... the 'both on' combo is then absolutely HUGE.
    I really wouldn't. The 'acoustic' sound you get is usually fairly unrealistic at best, and they have problems with reliability - the individual saddle transducers are more failure-prone than the simpler strips that you fit under the saddle on a normal electro-acoustic.
    I actually find a stereo split so you can run the standard magnetic pickups independently and put the *neck* one direct through the PA with a bit of EQ to bring out the top-end sounds almost as 'acoustic' and in some ways just plain better, without the problems.
