One thing to check is that you have enough depth in the cavity to accommodate the pot. As mentioned above, the switch part is on the bottom of the regular pot part and so you need more clearance to fit it in there.
One more thing - you might want to consider a push/push switch rather than a push/pull. The wiring will be the same but many prefer the action of a push/push in use.
have enough depth in the cavity (ooer missus).
Follow the right diagram you'll be okay.
Only other caveat I'd add is that the pots I've bought in the past have tended to be smaller, with smaller, slimmer connections for solder etc. Not a big prob but obviously you've got to be pretty neat and efficient with the soldering iron. Don't want to be weakening them through heating/ reheating etc.
Have you seen the Seymour Duncan site with its large collection of diagrams? Always a useful first point of reference.
@sreamabacus push/push sounds good.Any recommendations which make to go for?
Some say that push/push are not as robust as push/pull but whether that is down to poorer build quality or users' tendencies for over-enthusiastic hitting of a push/push, I'm not sure. I have replaced a push/pull where the owner pulled the shaft out of the pot, though.
Cheers.
http://www.wdmusic.co.uk/500k-pushpush-pot-with-us-specs-1124-p.asp
