I had a set that I tried on a Strat once in the hope that I could get rid of the string tree. It turns out that you can't get enough of an angle on the top two strings to dispense with the tree after all, which is why the Fender Eric Johnson model has a modified headstock. If that's why you're looking at the tuners, then you might want to be aware of that.
I put the tree in line with the d tuner - so it's a little further back than usual, but after a lot of experimentation I found it was just right.
