I was given these two pick-ups which I was told came out of a Parker Nitefly as the guy who bought it wanted a specific set put in. But I can't for the life of me work out what they are from Parker catalogues as the only Parker with pick-ups that are chrome covered come in sets of Seymour Duncan Pearly Gates and Custom Custom or Seymour Duncan JB and 57s.
I've never seen the back of an SD pick-up look like this but then I'm far from an expert! I did a quick test using a multimeter against the positive and negative parts of jack cable, which is clearly not particularly scientific, but I think both came out around 9 ohms.
Any ideas? Only reason I ask is I'm shifting them and want to try and work out what they might be worth!
My band, Red For Dissent
I don't think they're 'Duncan Designed', and they're definitely not real Duncans.
No point in removing the wax, there won't be anything else legible under it most likely.
Cheers!
