With various knobs, megaswitches, and wiring options out there the possibilities are pretty numerous, but which ones sound good enough to try and accommodate?
I'm pretty sold on having the beefy 'both in series' option in there, so presume this is doable either via a 4-way or a push-pull, is that right?
But what about phase options? Any good in Tele land?
I'm probably going to go with a DiMarzio Chopper T bridge pickup so that is 4 conductor, not sure if it's worth splitting or fine as is for mixed selections?
Any ideas, suggestions or experiences welcome. (even if it's the expected 'Leo was right, don't change anything, I know you can't help yourself so go for it ;-) )
Cheers
Tim
Red ones are better.
So traditionally, teles have always been modded!
I like the 4 way in series switch. @alnico uses it and it just gives you a nice, if quite hummy (in some places) boosted, fat tone.
Another common one is a blower switch - I *think* it just takes your bridge pickup and routes it straight to the jack via no tone pot which makes it a bit louder. Like having a small in built boost.
I know, but you've already been very generous to me and I have new 4-way switches at the shop, so I won't say
Relating to the question, my friend had a mahogany tele with a chopper T in the bridge and a P90 in the neck, the series sound was good, but it lacked the definition the other sounds had, it just sounded a bit muddy, he later replaced the bridge with a Lace Dually Blue/Gold, and used the 4th position for the gold only.
Pm me your address and I will have it on its way to you after the coming weekend. ......
Doo Dah, Doo Dah.
