When I look at people using them I get the impression they make you play with your picking hand in such a position as to get you a good slap from any self-respecting classical teacher. In order to get the thumb parallel to the strings so tha the thumbpick can work, the wrist needs to be flattened which in turn puts the digits into the wrong position for picking their strings properly. Whereas I play with an arched wrist, and the thumb approaching the strings from a 45 degree angle. IMO I play better that way, but as with all these things YMMV
I play lap steel with a thumb pick but can't get on with them on regular guitar.
I haven't actually used the ones that look like a "real" pick (have owned two thumbpicks, ever- one plastic Dunlop one that decided to snap one day for no particular reason, and the metal Dunlop one I replaced it with), but the ones I've played have stuck out way too far for me to use comfortably as a regular pick (I tend to have as little as possible of the pick showing) and can't be adjusted, other than with sandpaper or something.
@Phil_aka_Pip is right- I think you'd have a hard time playing proper classical pima fingerstyle with a thumbpick. My totally made-up, self taught lap steel style involves mostly my thumb and middle finger with occasional ring finger strokes (I use my first finger for harmonics). On regular guitar I do something similar- mostly play with a pick between thumb and forefinger and occasionally use my middle and ring fingers to pick extra notes (which might also explain why I can't find a use for my first finger on the steel). It's something like Travis picking I guess, which lends itself more to a thumbpick than pima does.
I think for a generation of guitarists in the US the only guitar players shown up close on tv were country pickers and so you get these old time country influences creeping in to odd places.
Grow a freakishly long thumb nail. It works much better.
Main benefit for him is it allows tapping while holding your pick. I think he also designed his own.
