If you can echo this emotional response in the solo, then you're on to a winner.
As to how you find the right notes, one way that's worked for me is to write out all the bars sequentially, then draw (yes draw) your solo with lines, squiggles, whatever as you're listening to it. You'll find that this form of short hand notation gives you the ebbs and flow of the feelings. Then it's just a matter of working on each section until you find the right runs, the right speed, bends, slides to best fit the freehand scribble. Try it, really, it gives you a fantastic sense of where you're going with it.
Once I've crawled back down from my own backside, I've found this has worked really well in the past for me. I've got a few sketches I could upload if you'd like to see.
This, however, largely depends on whether your singer insists on making every song about his sexual conquests, then just the usually fret jizzery will probably do
