The Joyo clone is a hybrid of versions 2 and 3 as far as I know. I don't know what versions the others are cloning.
One word of warning regarding the Joyo. It's a good 'in the ball park' OCD and great value for money but is a lot noisier than many rivals. The Dano is a better cheaper clone than the Joyo.
I thought they sounded a bit different, too. I didn't get to try them head to head (since the dano died and the joyo was a replacement for it) but my gut feeling was that the dano was a lot brighter. At the time I found the dano a bit bright into my amps whereas the joyo, being a fair bit darker, worked better. But I think my ears or preferences change all the time, and currently i find the joyo a bit dark for some things and with certain amps, I may well prefer the danelectro clone these days. But the iffy reliability is a problem regardless of how good it sounds- my other two danos are still perfectly fine, but I'm not sure how much I trust them.
EDIT: Also I think paid less for my joyo than the dano, i think. Not much in it, of course.
Like I said, I don't know which circuit versions the Dano and Mooer are based on. Its probably out there somewhere.
I have played the Mooer in a shop. It sounds pretty good, but the way they have all but one of the knobs really small would make it a pain to reach down and adjust it on the fly in a live situation.
Yes, I have the Danno Transparent OD (gold one) version 1 (which is supposedly the closest to the Timmy). It's the best overdrive I have tried. It really is transparent. It just gives you 'more' of the things you want, depending on how you set the controls. You can't get these any more so I don't know what I would do if it broke...buy a Timmy I guess!
I was thinking about getting the Drive (silver one) for distortion pedal duties just beause I like the gold one so much and it is supposed to be an OCD clone...although maybe the v2 is less of a clone than the v1.
I personally wouldnt bother with the real deal if i was using it at high gain levels but for mid to low i'll take the OCD everytime but give both a try and see if you think the OCD is worth the extra for how your using it.
Differences were pretty minimal in fairness. And I didn't really like any that much, bit lacking in any character (which is sorta the point...).
So what do people think of things like the Distortion + or Distortion III?
My review of the DIII
The other MXR Distortions are all quite different.
Compared to the OCD the DIII has quite a bit less gain and is more obviously distortiony. It has quite a rolled of high end so it works well into bright amps.
I agree, the v1 transparent od is very, very good.
