a bit shoddy from Fender
axisusaxisus Frets: 28354
Back of an acoustasonic, instead of nice ferrules we get this:
  • vizviz Frets: 10771
    edited July 2015
    Hmmm. Edited as I clearly got the wrong end of the stick. :)
  • Moe_ZambeekMoe_Zambeek Frets: 3447
    It's a hollow body is it not? Can't put ferrules in fresh air I guess...
  • axisusaxisus Frets: 28354
    Actually that is a good point, it probably is!
  • martmart Frets: 5205
    edited July 2015
    I'd guess the ferrules would stress the wood too much - it being much thinner than the inch plus of a solid body.
    That design, on the other hand, spreads the force over a wider area making it easier for the wood to bear.
  • ICBMICBM Frets: 73031
    It's also because the bar is grounded in order to use the strings as a shield for the magnetic pickup, as they are on a normal electric by grounding the bridge - but this guitar doesn't have a metal bridge. To do that with ferrules they would need to ground them all individually, which would be a faff.
    A much bigger bodge is the horrible rosewood bridgeplate on the front which appears to be nothing more than a cover for the bridge pickup hole so they can use a standard body. At least I assume that's what it's for and not a misguided attempt to make it look more like a normal Tele.
  • impmannimpmann Frets: 12720
    In fact, some Tele guys are fitting similar for better tone. Such as..
    https://m.facebook.com/TaipanTone?refsrc=https://www.facebook.com/TaipanTone
  • WezVWezV Frets: 16946
    edited July 2015
    indeed.   I quite like the solid block approach.  I have even built some guitars with a glued in ebony block so that no ferrules were needed at all
    looks better inset into the wood like that
  • 57Deluxe57Deluxe Frets: 7350
    Thats nothing - I was looking at that scratch!
    <Vintage BOSS Upgrades>
  • EvilmagsEvilmags Frets: 5158
    Accoustasonics make nice firewood.
  • the_jaffathe_jaffa Frets: 1843
    That's a bit un-kind(ling)
    The earlier HMT Tele with a proper acoustic bridge and a Lace Sensor is a really good-sounding guitar - the best-sounding 'solid acoustic' I've played. I would still own mine if it wasn't for the horrible wide-thin jumbo-fretted early 90s neck. (Which couldn't easily be changed due to the offset neck joint.)
