Why is 6/8 more awesome than 4/4?
It unquestionably is but why?
ဈǝᴉʇsɐoʇǝsǝǝɥɔဪቌ
    12/8 would be even more awesome, having 4 beats to the bar.whereas 6/8 has only 2
    But to be more helpful, I think it's the swing thing you get when you subdivide each beat into 3 (as opposed to 2, or 4). tbh I think it's why I can't play straight rock'n'roll, or funk. My semiquavers are crap, but my triplets are pretty good :)
  • ChéChé Frets: 305
  • vizviz Frets: 10743
    I think of time signatures like jam.
    4/4: Strawberry, raspberry
    3/4: Marmalade
    5/4: Apricot
    2/4: Chocolate spread
    2/2: Peanut butter
    6/8: Blackcurrant
    7/4: Bovril
    7/8: Marmite
    Is that the same system as everybody else?
  • bluechargeboybluechargeboy Frets: 1906
    3/4: Marmalade
    5/4: Apricot
    2/2: Peanut butter
    6/8: Blackcurrant
    7/4: Bovril
    7/8: Marmite
    At first I thought you were correlating syllables with beats, and wondering how you stretched "apricot" into five syllables! B-)
  • thecolourboxthecolourbox Frets: 9917
    6/8 is just 2/4 with triplet quavers, if your beat accents are correct
    soundcloud.com/thecolourbox-1
  • PolarityManPolarityMan Frets: 7301
    We often use actual triplets in 6 as well so feel wise it's nothing like 4/4 in triplets
    ဈǝᴉʇsɐoʇǝsǝǝɥɔဪቌ
    Is that 18/8 or two bars of 9/8?
    Um...neither...it's 6/8 its not like the bar gets longer when you play more notes.
    ဈǝᴉʇsɐoʇǝsǝǝɥɔဪቌ
    depends on the time value of the notes. Are you dividing your 2 main pulses into 6 semiquavers each? (this would be so much easier if keyboards could write music notation)
  • TeetonetalTeetonetal Frets: 7818
    edited July 2015
    No, it's not.
    No, no no..
     6/8 is not 2/4 triplets Technically the counting would be different. 1 2 3 4 5 6  vs  1 e a 2 e a. and as above playing triplets in 6/8 is nothing like playing triplets in 2/4
    the whole point with time sigs is that whilst things might sound the same they would be written differently, so tempo is also set differently...
    and the nail in the coffin:
    6/8 can have 3 crotchets (technically the middle crotchet should be 2 quavers tied...), 2/4 cannot possibly have 3 crotchets..
    What I'm saying is that we quite often have a piece in 6/8 where the phrase is predominantly in eight notes but there are also sixteenth note triplets.
    So the presence of a real triplet kind of prevents you counting it as 4/4 triplet time.
    ဈǝᴉʇsɐoʇǝsǝǝɥɔဪቌ
    No, it's not.
    Is too.
    ဈǝᴉʇsɐoʇǝsǝǝɥɔဪቌ
    6/8 has 2 main pulses to the bar, each subdivided into 3. 2/4 also has 2 main pulses to the bar, each of which may be subdivided into 3 by the use of the triplet. They are indeed counted differently, but most of us would agree they feel the same IF the 2/4 is played at n crotchets to the minute and the 6/8 is played at n dotted crotchets to the minute. Which time sig you write in depends on whether the default subdivision of the beat is into 3 - so use 6/8, and if it is only occasional then use 2/4.
    @PolarityMan I'd suggest what would stop you counting it in 4/4 is that you've only got 2 beats to the bar, irrespective of how you subdivided them.
    edited July 2015
    You can also get waltzy feeling, 6/8 too. I've never seen anyone attempt to count 6/8 in 2/4.
    ဈǝᴉʇsɐoʇǝsǝǝɥɔဪቌ
    waltz = 3/4. It would take a hugely slow 6/8 to sound like a waltz, and you'd have to accent the 4 just the same as the 1 to get it to sound like two bars of 3/4. NO. definitely not. 6/8 != 3/4 by any stretch of the imagination. See Eric Taylor's The AB Guide to Music Theory.
    edited July 2015
    No, no no..
    With respect, I disagree. I've generally counted 2/4 or 6/8 as 2 beats because on really long pieces of music it's a pain in the ass to tap quickly 6 times a bar when you only really need to tap twice slowly, and usually with my feet which cannot speak! So what you call the taps is largely irrelevant in my experience. But even if you do count the quavers (in 6/8) or the triplet-quavers (in 2/4), if you count 1 2 3 4 5 6 or 1 e a 2 e a with your feet it sounds the same. The bigger accent is on the 1st of the taps,  the lesser accent on the 4th of the taps.
    Yes it can, triplet crotchets ;) and contrarywise you can have duplet-quavers to total the same as 3/8 (or half a 6/8)
    Example of duplet quavers in a compound time sig (this is in 9/8 but the point is the same)
    I'll see if i can find a triplet crotchets in 2/4 example
    Not enough for it to sound like a waltz but there are definitely parts in 6/8 that feel closer to 3/4 than 2/4. There's also a common accent pattern on 1 and 5.
    ဈǝᴉʇsɐoʇǝsǝǝɥɔဪቌ
    Counting "1 e a 2 e a" tends to produce a lesser accent on 2 usually.  Counting 1 2 3 4 5 6 tends to produce only an accent on the 1. It might not be supposed to but it often does.
    ဈǝᴉʇsɐoʇǝsǝǝɥɔဪቌ
    edited July 2015
    I think his point on the waltz thing is that if 6/8 is performed correctly it should not be the same as a waltz because the accents should not be equal on quavers 1 and 4, rather that 1 is stronger than 4. I know what you mean though a lot of bands tend to miss this out so it sounds like a waltz more than it would do if done correctly :)
    Then it's wrongly accented if the accent is only on quaver 1! 6/8 is compound (ie dotted note beats) duple (being two of said beats to bar)
