How well do EL84s deal with both high gain and the high versatility demands thrown at them by, for example, H&K's 'meister range?
The current crop of trendy lunchbox amps favour EL84s, presumably mainly for space saving reasons given they aren't generally associated with high gain. So is it just a perception thing in our (my!) minds, because EL84s are primarily associated with the chimey clean and medium gain likes of Vox that they aren't as 'good' as EL34s and 6L6s for hefty low end and bruising crunch applications?
I understand it more in the 18w amps for power rating purposes and there won't be much spare room in a Tubemeister 36 head, but if they can fit 4 x EL84s in then wouldn't 2 x EL34 also somehow fit to get in the same 36 - 50w ballpark?
I have a VHT Special 6 (Single Ended 6V6). The Valve Junior I had before definitely had some harshness in the upper mids that the special 6 does not.
As a contrast, the rocker 30 sounds absolutely delish and had el34s I think, but only 30 watts so must have been wired a little different to the norm. Sorta like the laney lionheart, with 5 (yup, 5!) el34s to give 50 watts?
The thunder 30 is mega high gain sludge and metal heaven, apparently. And that's el84 iirc.
I never actually tried it myself, but someone else in store (who could play tasteful music...) was, and I was in awe. Just that and a digitech reverb pedal, and it was sublime.
I personally don't like EL84s in higher gain amps. I think they affect the overall tone and prefer something with a flatter response.
Bandcamp
Spotify, Apple et al
We were all in drop c, but his bass drum turned out to be a d or something, he'd never thought about it before. Once that was sorted, things sounded so much better, it was like night and day!
Bandcamp
