ELEMENT | Dynamic |
POLAR PATTERN | Hypercardioid |
FREQUENCY RESPONSE | 60-15,000 Hz |
OPEN CIRCUIT SENSITIVITY | -55 dB (1.7 mV) re 1V at 1 Pa |
IMPEDANCE | 250 ohms |
WEIGHT | 10.9 oz (310 g) |
DIMENSIONS | 6.97" (177.0 mm) long, 1.89" (48.0 mm) head diameter, 1.30" to 0.87" (33.0 mm to 22.0 mm) tapered body diamet |
OUTPUT CONNECTOR | Integral 3-pin XLRM-type |
ACCESSORIES FURNISHED | AT8470 Quiet-Flex™ stand clamp for 5/8"-27 threaded stands; 5/8"-27 to 3/8"-16 threaded adapter; soft protective pouch |
