Hi Guys.
A long time ago I used to program my own backing tracks using Cakewalk. I found the clicking notes onto the Piano roll method very intuitive and got some good results.
I'm wondering with advances in software, is there a similar package available now that will enable me to do the same thing, but with considerably better sounds than the general MIDI ones I was using in the past. Perhaps with the option of recording too (which I will get my head around later).
My Brother-in-law has shown me Reason and Ableton, both of which didn't seem to work as I've described above.
Any help would be greatly appreciated.
Hi Dan, there are basically two sorts of recording software (aka DAW) it seems.
Ableton, Fruity loops and others are of what I call the "cut and shunt" variety.
Cakewalk/sonar is more "linear" like a multitrack tape machine with a mixer. Others of this stamp are Cubase, Reaper and Samplitude. (the latter has only recently become mac friendly) You can download 30day trials of almost all the popular DAWs (forgot Studio One, getting rather popular) .
Whichever you get you really must cater for a dozen or so hours of slog to get into them. Fortunately, once you have a good grasp of one, the others are somewhat similar in that they all do much the same things, just GET there differently.
Have you got a decent Audio Interface? If not do Google " NI KA6"
Dave.
It's more the creation of my own backing tracks I'm looking into at the moment. So whilst I'm probably going to want to record over them at some point in the future, It's not so much of an issue yet.
I'm definitely not minded towards Ableton. I found I had to watch Ten minute tutorial to do each little bit. And then couldn't get into it in any detail to alter the work.
Which is why I probably liked the way Cakewalk worked with the piano roll. I can open the whole piece up, move notes around, drag them longer or shorter. Just suited the way I work I suppose.
I had heard of Sonar, but didn't realise it was the new Cakewalk. Does it work in a similar way with just more added in?
Nomad
https://twitter.com/spark240
Reddit r/newmusicreview
He didn't. He said he forgot it. Is it any good?
I think I'll have to try Sonar as it's likely to be the most familiar. I'll have to see if our distinctly average laptop will run it, or whether I have to factor in a PC.
Thanks again for all the suggestions. Shouldn't be long before I am seeking enlightenment again.
I will check it out too. Thanks.
Ha! Yes my late entry of S1 was probably Freudian !
I tried the freebie a few weeks ago and it crashed my normally very stable Asus+6core 3G AMD machine. I really must give it another go!
Dave.
