Back
looks nice to me, is it easy to play and set up?
http://i211.photobucket.com/albums/bb102/flanging_fred/Music/my guitars/IMG_20150825_230942049_zpsi7bprhni.jpg
How is £150 to whoever wants it?
As you have found out, there is quite a lot to learn about Floyds and setting them up properly. For instance, in your photos the Floyd is angling back into the cavity. This should really be set flat so the baseplate of the Floyd is parallel to the flat top of the guitar. This is done by balancing the tension of the strings against the trem claw screws inside. It looks like you need to unscrew the trem claw screws a bit. This will make the tuning go flat, so tune back up. Is the Floyd parallel to the top? If not repeat the process. This can take a while to get right!
Another method
1. press down on the trem bar until the baseplate is parallel to the guitar body
2. insert a wooden block (or something else) between the trem block and the back of the trem cavity. (you may need another pair of hands to do this) so that the Floyd sits parallel. This means the block has to be the right thickness! A block of paper will do at a pinch.
3. Release the trem bar, it should now stay parallel to the guitar body on it's own. The wooden block should now be wedged between the trem block and the back of the trem cavity.
4. tune up to pitch
5. slowly tighten the trem claw screws. Tighten one screw a quarter turn, then the next screw a quater of a turn and keep doing this across all your screws. Eventually the wooden/paper block holding the tremblock will eventually fall out due to gravity. Your Floyd should then be set perfectly flat and the string tension perfectly balanced against the depth of the trem claw screws.
This IS a hassle but a properly set up Floyd is a good thing™.
God, I go on a bit don't I? Oh and no parlour guitars here
