Squier Strat with the big headstock style neck, lightly aged scratch plate and knobs (all new screws) and pickup cavity shielded. Dyed and waxed (not a veneer, its a solid wood body) a few small dings in the rear of the neck that are very small and a surface crack from one bridge hole to cavity (highlighted in last photo) does not seem to affect anything just mentioned for transparency. I am not claiming a factory finish by any means but in excess of 10 hours work gone into it from the standard model and many parts sourced hence the price. Can post at cost and buyers own risk in two parts to avoid breakages. Will likely need setup to suit you. £150
