Instagram
Instagram
Instagram
Agreed. The guy I'm building it for wants ebony covers, but I'm going to see if I have any camphor off cuts big enough to be sliced as an alternative for him...
Instagram
There are two items in the design brief I have been getting my head around - to try to make this as light as possible without neck dive and to have covered pickups.
I have combined those two requirements by routing the pickup chambers both to the largest width / length - which is basically the neck pickup, squared up, taking a bit more wood and weight out. It has the added advantage that if the guy who I’m building this for ever wants to replace the PJ's with super-triple-gargantuan-flipper buckers, it'll be a doddle
The challenge was covers. Never made those before and I only had enough camphor left over for a single shot at it. I decided that I would go for free-hand routing the chamber and then cut the shape out. The camphor offcut still has the wenge veneer stuck to it, but I thought I would leave that on for the time being. Here it is during the chamber-routing process:
I went for the small router base on the little bosch because it's easier to see what is going on. I was aiming for a 1.5mm - 2.0mm thickness at the top and 5mm max sides (which will probably be sanded down a bit)
I then cut the shapes out with a pull-saw and did an initial tidy up with the sander. They will be sanded further to angle the sides a bit and dome the top a touch, and will have the veneer taken off and sanded down to finished height, but at least I now know I don't have to revert to redoing them in ebony! They finished at 1.5mm thick which I'm very pleased about![:) :)](/plugins/EmojiExtender/emoji/fb/1.gif)
Thanks
