Wanted: Small Valve amp for home use (80-£150)
As it says on the tin! :) Head or combo is fine. After a bargain! :) Could PX a Bigsby B70 and/or a V7 Vibramate into the deal to increase higher.
WHY?
  • andrewandrew Frets: 47
    edited November 2015
    Might be better under 'amps' ;)
    Can highly recommend a Blackstar HT1 or HT5 for that kind of money. I had an HT1 as my first 'proper' valve amp and it was great!
    Sarcasm is often hard to detect in writing. If in doubt - yes, I was taking the piss.
  • Mooer Little Monster Bassman style amp? 5w, valves, tiny
    I'm scared and I'm waiting for life
  • Valve amp? How big is your home? (is your home, how big is your home, I really neeeeeeed to know....)
  • MtBMtB Frets: 922
    Ampmaker SE- 5a head - single ended, 5w, hand wired (no PCBs here) 12ax7 preamp valve and EL84 power. Has separate gain and master controls, plus treble / middle / bass controls. No effects loop. Has 16 and 8 Ohm outputs.
    Has silver front panel and is housed in a marshall style head sleeve.
  • JoesaJoesa Frets: 86
    There's an Orange AD-5 on Bournemouth Gumtree for around £110
  • NiteflyNitefly Frets: 5069
    Fender Ramparte?
