FT My Green Hondo II LP for something fenderish
I spent ages on this but in reality I never use it, it plays great and the build thread is
hereImpossible to put any sort of value on it without risking a barrage of likely deserved lols so I'd rather swap for something else a bit more fender like as I alternate between playing my Strat and Tele. It's not perfect, I am not claiming it is just a playable guitar. There are some marks in the dye where the wood refused to take it, I think it may be sap or engrain or something like that. There are also two pieces of veneer one either side of the neck in the pocket as removing the nitro from the neck left it a tiny bit short. I shimmed the neck also as there was some string buzz with the action set low. A single piece of veneer fixed it fine. I probably spent more time and money on it that it deserved but was a great project while it lasted. I made the pick guard myself out of a piece of wood, again its not perfect and I never could decide if I liked it so never drilled any holes for it. The pickups are from a sammick I stripped and are supposed to be SD designed which I guess means likely not that good but they sound good enough to me.
My Trading Feedback can be found here: https://www.thefretboard.co.uk/discussion/62765/bad-alice/p1
I'd also consider a parlour or 335 type guitar or pretty much anything I guess lol
