Okay, so my local tame luthier seems to have vanished
I've replaced the PUs in my Les Paul successfully earlier this year. I'm reasonably competent with a soldering iron but how on earth do you get to all the bits on a semi?
The guitar in question is a Heritage H-535. Is this something I could tackle or do I need to get it to a luthier?
I tried the piping over the pots, I tried fishing line round the pots and I tried combos but they all just ended in a massive tangle.
I ended up using a metal kebab skewer to manoeuvre things into place using the loop on the end, a pair of tweezers and needle-nose pliers to grab things and old bike spokes to podge things about. Worked well in the end.
I also pretty much covered to top of the guitar and the edges of the f-holes with masking tape to help protect it. Worked a treat
I use tubing, it's off an old vacuum brake bleeder kit as it happens. The switch can be fiddled into place with fingers. For the jack socket I made a fake jack out of 1/4" steel rod, shaped like a jack so it clicks into place. Cross-drilled a hole with a guitar string through for fishing it through. A bit of good dowel could prob be shaped the same way.
Last time around I made a stiff card template and poked pots/switch/jack through that and wired everything there. Mainly because I did coil splits and wanted to be sure everything worked before shoving it back in.
Fun it is not, but not too bad a job either.
If you want to change the pot etc which In my opinion is not worth it if have them wide open all time then the previous post tell you all.
Hmmm, okay, on balance I'm going to go with finding a luthier then, sounds too much faff and fiddle for my taste![:) :)](/plugins/EmojiExtender/emoji/fb/1.gif)
Thanks for the advice everyone.
