Changing scale length on an archtop
Would it be possible on my archtop to fit a new fretboard with a different scale length?There are several pre made and fretted for sale on eBay and I was hoping as the bridge is a floating one it would be possible to compensate? As is probably very clear I have no real knowledge on the subject.
  • WezVWezV Frets: 16935
    As long as its not too far either way it will be fine
  • SkodadadSkodadad Frets: 510
    Cheers @wezv my other worry is that the archtop has a nut which is only used as a string guide. The first fret has the strings sitting on them. Should I use the first fret as the starting point for measuring to the 12th? The archtop only has 20 frets in total so I may have to either cut down the new fretboard or build a small block onto the top to continue from the neck.
  • JalapenoJalapeno Frets: 6409
    Think you mean a "zero" fret  - yes, start there.
    Feedback
    When I did mine i got rid of the zero fret and didn't pay too much attention  to the existing scale length. I measured  it all, but the original scale didn't match any modern calculations very closely
     The bridge on an archtop should sit between the centres of the f-holes, but in reality you can move it an inch or so either way and it will still be fine, certainly with a ply archtop anyway.  If you were going to move it further you might need to consider where the bracing is
    Ideal Cheers guys
    here is mine before -
    and after
    Very cool @wezv nice hofner too. Is it the Congress?
    yeah, i sold that one on though because I didn't know when i would get around to fixing it up
    I still need to attach the plate I made to the framus - cream pearloid to match the headplate
