I got 'em here:
http://www.craftycomputerpaper.co.uk/.-Laser-Water-Slide-Decal-Paper_155.htm
Were you using inkjet or laserjet?
In the case of laserjet it's just building up enough coats. However with inkjet because you have to coat it try and use the same lacquer as it is possible to a.) get a reaction and b.) notice that just like whites, not all clears are the same colour.
I said maybe.....
The MrDecalPaper stuff is ok, I found if I cut a piece to overlap the headstock edges and trim it back then I've only one edge to hide, and I get that (on 3+3 headstocks) between the top two tuners so it's much easier to hide.
http://www.thefretboard.co.uk/discussion/61134/sarge/p1
