Yeah I use it. It's messy stuff but are you dry sanding? What grade paper are you using?
My usual process is two coats about an hour apart, then dry over night. Then wet sand with about 400 grit until virtual all shiney spots are gone.. Dry off and let dry for an hour then two more coats and hour apart. Again just over night (maybe two depending on the time of day I did it) then lightly sand again.
Instagram
http://www.axminster.co.uk/chestnut-cellulose-sanding-sealer-ax21180
Instagram
You can, but its a horrendous job.
Instagram
