To the relic lovers, opinions on second attempt at defacing a guitar
My first attempt didn't go so well, I went to far with no real direction or planning. Thought I'd ask for some opinions at an earlier stage this time
  • simonksimonk Frets: 1467
    Is it poly or nitro finish?
  • SkodadadSkodadad Frets: 510
    It's paint over sanding sealer
  • ICBMICBM Frets: 73019
    It looks better than most commercial relics :).
    @icbm should I lacquer it then redo the relic areas?
  • NomadNomad Frets: 549
    Depends on what you want, I suppose. Nobody plays a guitar for 20 years to add wear, and then lacquers it - real wear starts with the finished item. On the other hand, if you want a reliced look that will be preserved (and not absorb sweat), then relic before lacquer (after which, the lacquer will wear and sweat will be absorbed anyway).
    Nomad
    Well I've done lighter paint coats around the relic'd areas so hopefully that area will wear naturally. The paint is thick enough to get a shine and I can then add paint swirls with a micromesh pad to dull it down a little.
  • axisusaxisus Frets: 28354
    Works for me. I like it.
    Cheers @axisus are there any more points you think I should take back a little?
  • DeadmanDeadman Frets: 3963
    I've done a couple now, less is definitely more and you need to take your time. In my humble opinion yours needs a few strategically placed chips and scratches. Maybe a white base coat as opposed to a black one next time too, if you're going for one of the old Fender-esque colours. Enjoyable isn't it? ;)
    It's nice not to have to be so careful handling it that's for sure. It's different to trying to get a pristine finish. I may give it to my boy to play with in the garden when the paint dries properly :) he will likely do a very convincing relic job.
    My Tele was mint in every way until I beat it up. I love the feel of it now. On the plus side, I whacked the headstock a few weeks ago by accident and put a 1" gouge in it and rather than cry I felt a sense of pride
    :D
    There is a certain appeal to them, my problem is as soon as I play it any illusion of a well loved faithfully old friend disappears. I'd have to pretend my playing was a 'style' rather than useless.
