A year ago I decided I wanted to understand my guitar a little better so collected some parts and built this good looking girl. She taught me a lot during the way but when she was finished I realized there is something wrong with it which I cant just put my finger on to work on it.So as you can imagine first thing I did was talking to a guitar shop in my local area just to be told that "guitar making is mathematics mate, if you dont know the mathematics there is nothing anyone can do" even though i offered to buy a new neck or change any parts of it.As you can imagine it really upset me to hear that this piece of equipment is as good as a sandwich package, just something to chuck in the bin.I dont believe that, I m sure with enough knowledge and skills it can be fixed. I am open for any luthier or technician advice around london area or just even telling me what my problem is.My tuner shows that my opens strings sound right but they dont as you can hear on the below soundclip, I ve checked my intonation with harmonics and and 12th fret still sounds fine. With the 5th fret some notes seem to be off tune but very slightly. Then again everything sounds still terrible so can someone tell me Why is it?is it because of my nut? neck? bridge? what the hell is it ?I am open for any advice on this and if you manage to point out my problem I will personally send you a letter telling how much I appreciate your help (only if you are ok with it obviously)
this is how she sounds like
and how she looks like.
Hope someone understands me. thanks a bunch in advance>>
What is the string height at the 12th fret?
How old are the strings?
Nomad
It is a standard strat really. http://imgur.com/a/c2PUu
The measurements are made from the fingerboard itself not the frets.
Do you think i need a new neck or a spesific type or extra shiving would be able to do the job for this?
Even if all the above are correct, strat pickups adjusted too close to the strings can magnetically pull the string and pull the intonation out.
This is a good video (check his channel for other excellent strat set up videos).
https://www.youtube.com/watch?v=i6dlN93MGgw
If in doubt, take it to a decent guitar repairer to evaluate. Feline Guitars in Croydon or Jon Dickinson in Crystal Palace would be my recommendations if you're in South London.
If not try Dan Erlewines book
It sounds like the nut to me - even in the fuzzy pics it looks miles too high as Steve said. Fret each string at the third fret - so it's also resting on the second fret - and have a look at the gap between the first fret and the string. It should be tiny - between 1/10th and 1/4 of the string diameter at most.
If it's higher than this, when you fret notes between the nut and the 12th fret, and especially nearer the nut, they will play sharp if you've set the intonation correctly at the 12th because you're effectively bending the strings to get them down to the frets.
Many guitars have a re-sale value. Some you'll never want to sell.
Stockist of: Earvana & Graphtech nuts, Faber Tonepros & Gotoh hardware, Fatcat bridges. Highwood Saddles.
Expert guitar repairs and upgrades - fretwork our speciality! www.felineguitars.com. Facebook too!
