Pivot screws are vertical, arm is angled back.
The arm is angled back so you don't need to remove the arm to put the guitar in the case - you swing it round to the back.
Yes thanks all. The Pivot screws, I thought they were vertical, but in this Fernandez body they seem to have been put in at an angle. Anyway I plugged them, marked up centre and position and will make a drilling jig, oif that doesn't work I'II rout out a bigger chunk and put a block in and start again.
Funny. I always thought the USA arms were angled back to give you more whammy leverage, never thought about the case.
