Okay...
Boss NS2.
MXR Smart Gate.
MXR M195 Noise Clamp.
ISP Decimator.
ISP G-String.
Obviously the G-String is the most expensive, and is meant to be the mutts nuts. and indeed having owned one in the past, I can confirm this. Ive also owned the Decimator before too, and it wasn't too bad - little bit of flutter as the notes die away, but nothing too serious.
I've never tried the others. Are they shit, just as good, etc..??
Ideally you'd be telling me the MXR stuff is as good as the Decimator. Because I have a credit note with Hotrox that I need to spend, but they don't seem to stock the ISP!
I've had both a Boss and (currently) an MXR.
The boss, when everything was turned up, very quick cut-off, Ideal for staccato riffing.
Not so good (but not bad) for everything else. And after a delay, cut any tails really short (even on low settings)
The MXR smartate is a better all-round gate, but can bleed a little for staccato riffing. Again after a delay can cut tails short.
I'd have another MXR, but not another Boss.
Looks like the ISP is the only go-er here.
Surely it depends on the setting, the MXR has a hiss/mid/full switch which varies the amount of attenuation.
Mines on hiss, to remove background noise.
It can do staccato stuff, but not as well as the boss. But for everything else, it's a boss beater.
Its Lukes pedal of choice
'nuff said.
I love mine
I have it 1st in line so it only kills my single coil noise.
Football is rubbish.
I use a Smart Gate infront for reducing the hiss/pedal noise. Works brilliantly for that.
