SOLD: Blackheart Little Ant 1/4W Valve head and cab
http://i629.photobucket.com/albums/uu15/erikryman/010-1.jpgI bought this for the living room, but seem to just play my AC15 instead, so tis on it's way.
Lovely condition < 1W and controls so simple even I managed to master them..
£99 Delivered, PPG or Bank transfer preferred
MR ReviewHere's the spec/blurb
The Killer Ant Half Stack is
The follow up to Blackheart Engineering's Little Giant 5, the Killer Ant
is the first attainable, boutique quality fractional tube amp.
Featuring Class A, Single Ended circuitry, it delivers the complete,
classic, touch responsive tube tone you need but at more manageable
volumes for apartment dwellers and recording sessions.
Designed on a beer stained cocktail napkin, prototyped, built and tested
in a one car garage in Austin, TX, and engineered to the same strict
standards as the Little Giant 5, this "little head" delivers the tones,
the smells and the attitude you want when sonic bliss is everything and
volume needs to be kept at bay. The Killer Ant embraces 100% classic all
tube circuitry but, instead of a high power tube output section, it
boasts a clever, all tube power block pumping out a mere fraction of 1W.
What you get is arena rock tone at bedroom levels. No more angry
neighbors, whining wives or girlfriends (or both...just sayin').
Like its big bro, it features completely overbuilt component specs, from
1W resistors in the signal path to double sided PCB with 2 oz traces.
Even its diminutive cabinet, just over palm sized, is built to take a
beating with 15 ply (18mm) void-free wood covered expertly in durable
black tolex. Final touches include distinctive white piping accents and a
salt & pepper cloth covered front baffle. 4, 8 and 16-ohm extension
speaker jacks allow you to hook the Ant into virtually any cab you
like, including a 4 X 12. However, its counterpart, the Killer Cab, is
designed to be its perfect soul mate.
Blackheart Products have been discontinued and are and end of line product. All Products are brand new but have been on display.
Specifications
Head
<1 Watt RMS, Single-Ended, Class A
» Outputs: 1 x 16 ohm jack, 1 x 8 ohm jack, 1 x 4 ohm jack
» Preamp Tubes: 2 x 12AX7
» Solid State Rectifier
» Volume (the rest of the tone is in your hands)
» DC Power to filaments for super quiet operation
» 15 ply, 18mm thick-void free plywood construction
Cab
16 Ohms
» 30 Watts power handling
» 15 ply (18mm) thick, void-free plywood construction
» 10" Blackheart Model 1016B by Eminence Speaker with British Voicing, optimized for closed back cabinet
» 2 x 16 ohm parallel speaker jacks
I forgot I got it off you @Deadman....still sounds good
you don't want any trades do you? I have a Fatboost 3 and a couple of humbuckers i'm moving on.
she's ok with the "GAS = n + 1" on guitars and pedals, but not on amps...:(
Good luck with the sale mate
As an aside I want the Sly & The Family Stone version of Que Sera Sera played as my coffin's rolling into the big fire but that's by the by.
I appear to be a little short on bargaining tokens at the mo' as a consequence of the voracious rate of my recent pedal acquisition, and that being the case I don't suppose that either yourself or the burgeoning guitar talents of Jooky 2.0 would have use of either a Providence Sonic Drive or a Gig FX Frampton Megawah (quite possibly the most highly specc'ed Wah wah on the surface of the planet) in part ex for this little gem would you ?
Gone to the good Doctor
