So, I've had a closer look at the main board, and I found 3 faults. One was a socket unplugged, one was a slightly cracked socket (both could indicate a big knock in the post). The third is D1, which is located by the 9v input socket and I'm presuming it's to protect from AC or high voltages. It looks like it has a small crack in it and the wire either side looks to be oxidised - which could indicate it has served its purpose and protected the rest of the 5 boards!
SO
Are there differetn varieties of 1N4003? Or is one the same as the other? I ask as I'm going to get one and solder it in.
Also, how would I effectively desolder the old component without burning the rest of the board? It's quite a tight squeeze (I'll take a photo in a bit).
Cheers for any advice!
I'd imagine the 1n4003 could be replaced by any number of more attainable diodes. I've some 1n4001 if that's confirmed - can post
(Which does bring into question what happened to the rest of the circuit in the same event that caused the diode to fail...)
I'll fix the diode, test it then look at the rest of the boards (all of the other 4...).
What components are most likely to cook? Hopefully not the digital chips...
Nothing will cook or have cooked with D1 be absent if the pedal is working otherwise. Most dead diode that have died in battle tend to show no sign of damage so there are probably plenty in pedals serving no purpose anymore. The only really offer an very short term of protection. I have however seen a fair few crack diode the where not cracked in the course of duty so it is possible this diode never saw any really action.
It's also worth remembering that this is from Ibanez cheap range of pedals made with cheap labour. If the pedal works fine otherwise it would not totally shock me to believe that a cracked diode was installed or the diode suffered a physical crack during installation. As it's only there for protection against something you are unlikely to do how would you ever know?
My belief is that companies do not install reverse polarity diodes to protect their customer as the protection time is quite short. It's there so if you return a fried pedal they can look and say "You must have used the wrong polarity.".
As both Frankus and ICBM have said the particular diode you use isn't really essential, although you have ordered 1N4003s the only difference between those and the 1N4001s is current handling being 200v as opposed to 50v which would obviously make no difference to you.
Edit - I though the pedal was working otherwise, but sounds more like the diode gave out and opened up the rest of the circuit to damage.
I'll keep it in a bin for spare parts I guess!
Check you've got 9V at pin 8 of IC1 IC2 & IC3 ; 4.5V at the junction of R3 & R4; and +5V coming out of IC7.
If these voltages are OK, you can check whether IC1 / 2 / 3 are functional by checking the voltages on each group of 3 pins that is one op-amp are all at the same voltage (i.e 1,2 &3 should be the same voltage, as should 5,6 &7) - probably about 4.5V.
If there is no 5V supply, it might be worth taking a punt on changing IC7 (Maplin N69CA should be a drop-in replacement but they rob you blind for them - 99p!). A 79L05 would probably work for testing on a PSU.
That's probably as far as I would go.
If the supply has been reversed and there are any tantalum caps in the circuit (like little beads, rather than cans or boxes) they will likely be shorted - they *really* don't like reverse voltage that 'normal' electrolytics usually survive. The chips won't like a reversed supply voltage, either.
