Also to expand a little the solder is there to reinforce the joint, so you should make a good solid physical joint first, the solder just holds it together.
There are some metallurgical effects fromt he soldering too but they're minor.
I used to be shit at soldering until I learnt that the idea was to heat the thing you are soldering first and then melt the solder into it. Obviously the more powerful/hotter the gun, the less damage you do to pots and stuff. Be that a wire and pots held down together or two wires or whatever. A hot iron helps as does rosin core solder as it does to hold both things down together with something (A third hand?) and use flux paste on the thing you are trying to solder, although you can hold them down with your left hand and also hold and feed the solder into the hot things with that too. The solder should spread out and flow on it's own.
I still forget though and try blobbing solder on to cold things for a few goes until it comes back to me though every now and then.
If you solder properly the solder joint will be as strong, if not probably stronger than the wire itself.
Yeah, planning on keeping the old harness intact so I can swap back easily if I want. I like the actives live, but find them tricky to mix when recording via zoom b3 as they sound so big
