Maybe not strictly making or modding but better here than elsewhere I reckon. I want to chop and change some humbuckers between guitars with different colour hardware. I'm looking to remove a set of Seth Lovers with gold covers and replace with an existing set of Lollar Imperials from another guitar with Nickel covers. I'm not much of a tinkerer so I've never really considered this before, but are the covers interchangeable (assuming dimensions are the same) - if so how do you remove and replace them - are they push fit or soldered or something else?
And while I'm here, neither set are coil tapped. Am i right in saying if they were not originally wired for it they can't be subsequently wired correctly?
Thanks in advance - I'm threatening to get my "used only once" soldering iron out and set to with it, so expect more posts down the line..................
If the pickups have only signal and earth connections (i.e. braided cable) then you'll have to re-cable them to split the coils. Probably not a job for a second-time solderer.
