Speaker cab baffle
This weekend I am finally buying the plywood to start making a speaker cab.
I want to make something like the 2x12 Mesa Rectifier cab.
I wanted to go 18mm ply for the top and sides and 15mm for the baffle and back.  I'm finding 15mm ply hard to find (at least in smaller sizes because I don't really need a full sheet).  If I ditch the 15mm, would I be better with 12mm or 18mm for the back and baffle?
  • ICBMICBM Frets: 73070
    18.
    It's going to be a heavy cab, but if you want to get the sound of the Rectifier cab that will help.
  • CHrisP86CHrisP86 Frets: 360
    Cool, thanks.  I guess sticking to one size helps me economise on the materials a bit.
    I might stick to the compact rectifier cab dimensions to keep the weight down a bit!
