Li-Ion Rechargeable Battery Pack as power supply?
ddloopingddlooping Frets: 325
Hi all :)
Has any of you successfully used a Li-Ion rechargeable battery pack to power a few pedals?
Something similar to this one.
  • Never used one, but there are guitar specific ones:
    There was an Eneloop one too, dunno if it ever made it over here.
  • ddloopingddlooping Frets: 325
    edited December 2013
    Thanks, Chrispy, I did know about the guitar specific ones but they are almost 4 times the price of the one on ebay.  :-S
  • MaxiMaxi Frets: 13
    They should work a treat , you might have to make a reversed polarity dc to dc  lead depending on out put of it and daisy chain from there... thats pretty basic work and could save a few quid . You can use pretty much any type of rechargeable pack as long as it doesnt fall in voltage all that quick . I was thinking of using a 12v lead Acid pack at one point . Its a good way for insuring silent power supply IMO without worrying about one of your numerous 9v batteries going flat . The other benefit is that a nice sized battery pack can handle more current draw vs power supply . A motorcycle 12v battery would easily last all day .
    Flown the nest .
  • I've thought about doing this a few times - there are some decent-looking 3900mAh solar-rechargeable packs for digital gear that support 9V, and they're usually on the order of £20. Certainly a damn sight cheaper than the Volto, and they're slim enough that they should fit under most boards.
    <space for hire>
  • Thanks, guys, I might get one after xmas. :)
    Hmmm, interesting thought.
    Potentially green, too, depending on the manufacturing process (not familiar with it). Which, to me, is nice.
    Linky? :)
  • Likey linky tooy   :D
  • RockerRocker Frets: 5022
    Recently I bought a replacement 12 volt Lithium battery for my golf trolley.  The old lead acid battery is now available and I hope to try it out [on my pedalboard] sometime over the Christmas period.  I wonder if Russ Andrews has a suitable cable for the job... :))
    Nil Satis Nisi Optimum
