I'm getting to the point in my guitar build where I need to start figuring out the wiring but I'm a wee bit lost.
I need to buy a pair of pots, one volume, one tone and I also need to cap for the tone pot.
The setup I'm going for is a pair of humbuckers, a three way switch and a pair of mini switches for splitting the coils and it is this splitting that is confusing me. If I just had the humbuckers then I'd probably be going with 250k or 500k pots but due to the splitting option I'm not sure whether this would work ok or not. I guess the middle ground of 500k makes some sense but could do with some back up on my thoughts from someone more knowledgable.
The splitting also seems to confuse things on the tone pot cap. With humbuckers it seems to be that a 0.047 cap is the recommended option but with single coils it seems that 0.022 caps are a better option. Any thoughts as to which would be better in my situation?
On the taper front, I understand that an audio taper for the volume pot makes sense and that a linear taper makes more sense for the tone pot but can anyone help back that up, confirm or deny please?
Any advice would be greatly appreciated, cheers.
Interesting comments on the values in your last paragraph too.
Cheers
while i think i understand what to do (having built quite a few stompboxes), rather than guess (or use someone else's guess) it would be nice to have a guaranteed bullet-proof wiring diagram to avoid messing up.
as to pot values, others know better than me and i will learn and take notes. the splitting thing confuses me too. do i need a separate cap for the 7k single coil and the 14.5k double coil of each humbucker is what i'm stuck on.
good luck with yours.
have been looking at various schemes across forums and websites but never sure how reliable they are. don't want to put the whole thing together, string up, then find i missed a ground and have to strip right back down. stompboxes i'm confident with but amps and guitars trip me up.
hope progress with your squire jagmutant is flying along.
For the tone control it's usually best just to choose the values that work best for the sound you will use the most, and give the control enough range to cover any fine-tuning.
If you are using one mini-switch per pickup, I would use the extra pole to switch a resistor to give an effective 250K volume pot (with a 500K volume). You need to wire the two switches as an 'either/or' combination so the same resistor is added when either pickup is split, not with two resistors.
If this all sounds like Chinese I'll see if I can draw it out for you later!
In the mean time I would get two 500K log pots, two mini-switches, a .022uF cap (unless you want a really deep single-coil tone with it rolled off, in which case .047) and a 470K resistor.
i don't want to hijack jaffa's thread but it sounds as if we are trying to do the same thing, so hopefully this will apply to us both.
all the bits i have if the switches are dpdt on-on, if they are on-on-on i will raid something or get some in. i only want single/double not phase, etc. have 1/4w mf resistors and cc which may be rated higher.
cap thing i agree re kiss. i tried a blues hawk with multiple tone stacks on a rotary switch recently that was interesting. didn't rate the guitar but the switch was cool. but less to go wrong best for guitar onboard controls.
have got a weird brown square 01/400 cap on the tone atm (c1971 with the guitar i think). not seen before. but will reuse as works perfectly with the (unsplit but split-able) hums it is attached to.
thanks for the offer of the diagram. it's generous of you (and tempting). i don't want to be a lazy b so will try and work something out first and pm you for approval or suggestions. long overdue learning. am sure i understand the tech but lack the confidence.
