Single pick up strat
birdobirdo Frets: 24
edited April 2016 in Making & Modding
I ve got a bit of a quirky strat ( ex jooky then re sprayed as war of worlds and fitted with Texas specials ) . Thing is I tend to think if I wanted a 3 pickup strat I should have a standard one. So I thinking about converting it to a single humbucker that splits or single p90 . There seem plenty of pick up options from oil city but putting it in to a scratch plate and doing the correct wiring is maybe a bit beyond me. First off is this a good idea ? Secondly any pick up suggestions and thirdly is the wiring and scratch plate as tricky as I fear or is there someone who would do this for me. http://i1303.photobucket.com/albums/ag158/Jlb7720/image_zps96b98cc8.jpg This is the guitar in question .
  • Do all three options- fit a Seymour Duncan P-rails pickup. HB, P90 and single coil in one HB sized bundle of fun.
    I don't imagine that wiring it would be too difficult- take your time and follow a CLEAR schematic diagram (if you post it on here I'm sure folk will happily check it for you).
    I converted my telecaster to an Eldred Esquire with no previous soldering experience & it worked (after some tinkering) so I have faith in EVERYONE else's ability to do similar things.
    Good luck
  • DrBobDrBob Frets: 3023
    Probably worth checking (if you haven't already)that the body is routed for a full sized humbucker
  • birdobirdo Frets: 24
    It's got , I think they call it, a swimming pool route. Basically tons of room for most things.
  • Winny_PoohWinny_Pooh Frets: 7900
    Right then you're Golden, let's do this !
    Ok so for nothing too high gain, just mainly cleans to a bit of bluesy crunch. Is a split able humbucker the way to go. I do want the option of a couple of tones . Although the idea of something gretsch like in there might be quite cool.
  • TTonyTTony Frets: 28071
    That looks fantastic. What does the mini toggle do and how does it sound?
  • english_bobenglish_bob Frets: 5228
    Yes. That was my first thought. Apparently it's in Nashville tuning.
  • EricTheWearyEricTheWeary Frets: 16432
    The Fender custom shop Luchador has Gretsch like TV Jones pick ups and there is a one pick up version. Strat outline, although not all the contours IIRC. Not everyone's cuppa but cool looking guitars to me.
  • GSPBASSESGSPBASSES Frets: 2357
    Changing the subject just a bit, looking at the original picture of the Strat I see it has graphics of the War the Worlds tripods or aliens. Last week I went to see Jeff Waynes War of the World's the musical at the Dominion Theatre absolutely brilliant, if you want a good night's entertainment then go and see this. If you can, try and get seats near the front of the stage as when the explosions come the flames appear all along the front of the stage it so hot it nearly singes your eyebrows.
    The p'up is a DiMarzio P90-sized HB.
    Because the body is so thin, I didn't have the depth for a push/pull pot, so I used a mini toggle to coil-split the p'up.
    Then I sold the p'up, so it's currently rather sound-less!
    I saw it at Sheffield Arena years ago. Justin Hayward was on stage for pretty much exactly as long as it took to sing that one song, and I about pissed myself laughing when the war machine descended from the lighting rig. Stoooone henge!!
  • paulnb57paulnb57 Frets: 3112
    I did my wonky Strat with a HB sized P90....loved it!
  • koneguitaristkoneguitarist Frets: 4221
    Just stick a P90 pickup in it with Vol and tone, you don't need anything else! HB's are for girls....... %-(
