Les Paul shielding
Is it worth lining an historic LP's cavities and covers with copper tape?
Is copper tape the best material?
If so, where's the best place to get the right stuff?
TiA.
  • Adam_MDAdam_MD Frets: 3421
    edited May 2016
    Slug repellant tape. Do not buy any from a guitar retailer it's way too expensive. I bought a huge roll for £1 from Amazon last year.
    I've shielded my strat but not my les Paul or my tele.
  • sweepysweepy Frets: 4221
    I prefer condec conductive paint tbh, a lot neater and less lacerations from the copper shield ;)
  • ChalkyChalky Frets: 6811
    Never spotted the difference that shielding makes - anyone advise what I am missing?
  • ICBMICBM Frets: 73128
    No.
    A Les Paul with proper braided cabling is already very well-shielded, by the cabling and the pot casings. The only parts that aren't are the tiny lengths of exposed wiring at the pots, and the tone caps - although even these don't make a lot of difference if they're arranged with the outer foil (indicated by the band on some caps) at the tone control end rather than the volume control.
    If you must do it, conductive paint will make all the extra difference that anything can - it's not as effective as foil in totally unshielded guitars, but the difference is so marginal here that it's not worth worrying about.
  • digitalkettledigitalkettle Frets: 3374
    That'll do then...thanks chaps ;)
  • FelineGuitarsFelineGuitars Frets: 11772
    We use a nickel shielding paint that works REALLY well
    Available as an aerosol if you prefer to spray (make sure you shake it up well)
    It's important to run a wire from any isolated cavity that you screen to the back of the pot that is the last point before the earth wire goes out to the jack.
