My go to guitar is currently a Vintage AV3 semi (335 copy)
It plays and sounds great but I'm sure it could be better.
The previous owner had already replaced the pick ups with some SD Jeff Beck humbuckers which are great.However the neck pickup sounds a bit muddy. I'm fairly sure the pots weren't change so this may be part of the problem. The guitar also has a sort of coil tap control knob which also sounds dreadful on anything other than full humbucker setting.
What I would like to get done is :
Upgrade the pots
Rewire everything
Replace tuners
Any idea how much this would cost?
