Switchcraft 380 jack plugs
Are these any good? They don't seem to have any kind of strain relief, but look nice and compact for going in to the back of a G2 ...
ta
Tim
Red ones are better.
  • ThorpyFXThorpyFX Frets: 6237
    ta
    Tim
    switchcraft stuff is awesome, you are right though... no strain relief. I'd put 2" of heat shrink over the plug to add some
    Adrian Thorpe MBE | Owner of ThorpyFx Ltd | Email: thorpy@thorpyfx.com | Twitter: @ThorpyFx | Facebook: ThorpyFx Ltd | Website: www.thorpyfx.com
    ThorpyFX said:
    ta
    Tim
    Yep, pretty common practice
  • TimmyOTimmyO Frets: 7775
    Cool, so if I were getting some of this stuff :
    what size would I use? Planning to use Switchcraft 380 plug and Van Damme XKE cable
  • SporkySporky Frets: 29208
    Get just big enough to go over the plug, then it'll shrink good and tight.
    That said, use Neutrik jacks. Best strain relief in the world.
    Too wide for G2 loops I think, and annoyingly long - I like the compactness of these
    They're only 1.8mm wider than the 380s (14.5 vs 12.7) - so probably narrower once the heatshrink is on.
    Though fair on the length - even with a good length of heatshrink they'll be shorter. I thought you had space at the back of the G2?
    edited May 2016
    Currently have a mini pedal and some power gubbins there.
    Would be doable probably. Hmm.
    Sorry, I'm always complicating things!
