*TRADED*
Up for Sale is my VOX AV15 Analogue Valve amplifier. I recently bought this then acquired a Bassbreaker 007 not long after so this is a bit surplus to requirements.
It's solid state circuitry but with a valve pre-amp much like the valvetronix series yet it's not a digital modeller but an analogue circuit. Make of that what you will but I think it sounds brill.
For an 8" speaker it does have some fullness to it, I wouldn't expect it to handle a gig but it can get pretty loud in a bedroom setting!
Has your usual clean, crunch, overdrive, hi-gain amps. Has bright and Fat switches and you can change the biasing of the valve from cool to hot. It really does have a load of tonal options along with it's three band EQ and power level.
Specs:
- Eight analog preamp circuits to reproduce the sounds of eight tube amps, from clean to high-gain, with careful attention paid to circuit design and selection of parts
- Pre- and power-amp sections use the 12AX7 dual triode tube, delivering real tube sound
- Four modes modify the response of the vacuum tube peripheral circuitry
- High-quality modulation, delay, and reverb effects are built-in
- The cabinet is constructed with an integrated baffle for efficient sound projection
- The speaker unit is mounted from the front, providing loud, clear, and spacious sound
- A proprietary bass-reflex structure delivers natural sound balance
- Power level control allows the volume to be adjusted while maintaining the tonal character
- Headphone out is equipped with a cabinet simulator for realistic sound & presence
- Send/return and speaker output are provided
- Hi-fi spec AUX input allows an audio input source to be faithfully reproduced
Pics:
Apologies if the last pic isn't at the correct orientation, Photobucket is up to it's usual tricks!
Looking for £75 collected from me, based in Greater NW London, five minutes from Heathrow Airport. I could potentially ship this at additional cost if really keen.
Thanks for looking!
https://www.thefretboard.co.uk/discussion/57776/handsomerik/p1
