Just done the true bypass/LED mod to my Crybaby GCB95...
...but the switch is shorter than the one I replaced so I can't actually toggle it!
What can/should I do? Is there (a) an obvious way to reduce the gap between top of switch and underside of treadle? (Currently considering adding something lumpy under the treadle).
Or (b) do I chastise myself for being too impatient, source a longer switch and do it again?
If (b), any ideas where to get one?
Here's my trading feedback thread: http://www.thefretboard.co.uk/discussion/61795/
  • ICBMICBM Frets: 74396
    Glue a small rubber grommet into the recess on the underside of the treadle.
  • gingerbbmgingerbbm Frets: 33
    Thanks. What sort of glue would work on the metal casing?
  • SporkySporky Frets: 30139
    Epoxy or superglue at a guess.
    Superglue worked! Ta :)
