Hi
One of the projects I've recently completed - trying to renovate a very old and very falling to pieces bass, involved my normal staining with ink. The owner wanted orange for the front ash panels and the back - re-panelled in walnut - to coordinate.
However, he wanted an old-look organic-feeling satin finish. It was just shouting out for the
@WezV tru-oil slurry approach. However, I have always shied away from trying a slurry with stain....for obvious reasons: if you slurry the top of the wood, then you will slurry off the stained timber.
I gave it some thought and tried something out:
- what if I used the Birchwood Casey clear sealer / filler, couple to three decent coats, and let it dry pretty hard....
- ...then slurry not the wood, but the tru-oil filler base and buff as normal?
To my surprise, it worked really well. Here's the stained walnut:
It's still got that silky 'wood' feel and there was very little lifting of the stain.
I then tried it on the top ash panels. This had some additional dirtying applied, adding a small amount of dark stain to one of the coats of tru-oil and applying it in normal wear areas, then finishing with a final slurry coat which softened the dirtying and buffed nicely:
It would be a real bonus to be able to use this again in other applications so I'm repeating the experiment with a GSPBasses double cut junior second I bought last year (it was a second because apparently the radius on the edges isn't period correct. Seems a pretty d****d fine build to me!). It will be eventually wipe-on gloss finished, but on the road to that point, I will do a slurry/buff stage and see how it does.
I've started it and will let you know how it goes. From a standard mahogany, I've so far stained it with Diamine 'Wild Strawberry' ink and given it a couple of coats of Birchwood Casey Sealer/Filler:
Results look good though
Instagram
Instagram
have you varnished over oil before? I only ask as I had not-great results with clear spray acrylic over oil on headstocks and after unscrewing the trc, the cover took a big ole piece of clear with it, just separated from the oil with ease.
http://www.thefretboard.co.uk/discussion/61134/sarge/p1
I have a tin of hardglaze too, what do you use to thin it and is the end result durable?
In real life it's actually a much better colour....Canon cameras struggle with reds. If you've seen the Gibson wine red gloss in the flesh, it's a dead ringer
