Hi, I recently purchased a Mockingbird type home built guitar from Ebay. Don't frown! the guitar plays like a dream and was dirt cheap. It came with a Lace Powered by lace pickup in the bridge pos and i've since added another in the neck. Prob is I want to rewire completely as I took it apart to wrap in auto/car vinyl. I'll add some pictures when complete.I have been on the lace and symour duncan websoites for wiring diagrams and also googled mockingbird wiring diagrams to no avail. I haven't wired a a guitar in a couple of years and am lost. Some one please help.!!!
Many thanks in advance.
NB: I'm just looking simple straight forward wiring job, no phasing, paralell etc.
2 lace hb's, 1 vol pot, 1 x3 way toggle switch.
![IMG_20160620_101428862](https://c7.staticflickr.com/8/7690/27517122750_5bb5accbff_z.jpg)
Both inner terminals of the switch to the left terminal of the volume pot as you look at it with the terminals towards you.
Middle terminal of the volume pot to jack hot connection.
Right-hand terminal of the pot to the ground of the jack, and the casing of the pot.
Both pickup grounds and the bridge ground wire to the volume pot casing.
Does that make sense?
I've never had that fail no matter how rounded the nut.
(You'll need a grinder to cut down and taper an Allen key, they're hardened.)
If you don't want to re-solder them all, the easiest fix is to put a strip of masking tape under the terminals of each pot - just under the terminals, you still want the threaded bushing to contact the shielding foil. (Yes, I have done that too if re-soldering things looks like being a nuisance
