So due to the case of my tech 21 double drive falling apart, (the base was being held on with one screw as the rest had snapped!) i decided to re house it, a technician at my uni offered to do it for me, and as i have no experience i took the opportunity, however after i received the pedal back from him i realised it needing fixing.
@roland kindly helped me and managed to find that the holes for the jacks weren't large enough meaning they didn't fit through causing the circuit board to bend in order to making it fit. the holes for the jacks were also drilled at very different heights so even after reaming out the holes to fit the jacks the circuit board sits at a massive angle, resulting in the pots being at an ok height on one side but not able to properly reach through the enclosure on the other, he also took off the led to re drill the hole for the led as he drilled it on the wrong side! basically its going to need a whole new enclosure, the main issue is i don't know where the led goes back on the circuit board, does anyone have a schematic for it or a picture of where it is soldered to?
heres the original enclosure
Thanks in advance for any help
Looks amazing @roland
You just missed a bit...
It should say 'VERY Limited Edition' at the bottom right .
