So, last night I pluged in my 6 year old Black & Decker 12v cordless drill / driver to charge as I needed it for some stuff tonight When I got up his morning I gave it a try and nothing, absolutely dead. So, the question is how do I go about identiying the faulty component?
I have a multimeter but no oscilloscope ;-) and I don't think I've got another 12v centre positive charger.
My current thoughts
Charger - Plug in and test connector with mm
If not then
Drill Unit - Plug charger into drill (it goes into the rear of the drill handle) and check the battery connectors at the bottom of the unit with mm
If not then
Battery - but I've got no other way of charging it
and yes, I'm bored at work
If it's 'dead' and not making any noises it's almost defo the battery, possibly the switch, but most likely the battery especially if the drill has previously not shown any dodgy switch issues.
I'd charge the battery then check with MM for voltage across the terminals.
