THR glitch?
rolls1392rolls1392 Frets: 238
edited January 2014 in Amps
When I use any other setting, other than clean, there a high pitched whine in the background.
It happens with both my Tele and an HB guitar.
Have plugged THR in various places with same result.
Faulty THR?
Pups on guitars need shielding?
Anyone any ideas.
Ta
  • TTonyTTony Frets: 27932
    Is it from the amp, or the PSU?
  • ROOGROOG Frets: 562
    That doesn't sound right, mine is quiet except from a little noise when using the hi gain settings.
  • rolls1392rolls1392 Frets: 238
    My THR whines loudest on the lead setting.
    Only guitar lead plugged in, whether guitar attached or not.
  • Mines all good. No problems
  • I had a similar problem when I bought mine.(sort of a weird fuzzy feedback kind of thing???) I phoned the shop and straight away the fella said go into the editor and turn off the noise suppressor. It worked for me!
    The Swamp City Shakers
  • TimmyOTimmyO Frets: 7710
    The frst batch had power supply issues- if you bought it then or 2nd hand that might be it ...?
    Red ones are better.
    Have tried above and it didn't, really.
    Have asked GAK for help.
    Thanks guys
    R
    Good point @TimmyO, you could try it on batteries to see if it improves.
  • FretwiredFretwired Frets: 24602
    Is it this?
    Yes.
    This doesn.,t sound normal
    Thanks
    R
  • thats not the noise i encountered. doesn't sound good though. hope you get it sorted!
    rolls1392 said:
    Yes.
    Thanks
    R
    It's odd as the the noise can be 'dialled' out of the amp. You should return it like the guy in the video. Mine doesn't make that noise.
  • Thats a major fault right there. still under warranty?
    Thanks for your help with this.
    Amp is being returned to GAK
    R
