The colour does darken the more you spray so I recommend sealing with clear gloss, applying the tint until you have the desired colour, then more clear to build up finish thickness
http://www.manchesterguitartech.co.uk/2013/03/13/spraying-the-neck/
It's out of stock at the minute I'm afraid but I'll have more in a few days.
Some ambers are different, because i used a stewmac amber tint i have to put brown in.
I only used the tint after a light clear coat first because it will get too dark as Steve said.
I will say though that i'm spraying with a gun so it's probably different to cans.
(formerly customkits)
