it does nothing for you then go back to regular stuff. No harm in trying.
This is in a Lexus NX, which is a 2.5 petrol engine.
Any slight increase in mpg would be negated by the extra journey.
I think from everything I have read v power is the best, then momentum, then bp's equivalent premium
Uk refineries produce a winter and summer blend that has slight octane differences more so for the winter when a lower flash point is a real bonus.
EDIT: Also - how fecking expensive is fuel round your way??!! :-o £1.23? I thought we had a bad deal at £1.12 for the premium stuff.
What app are you using to track this, btw?
I think I'll give it a go...
I put Shell V-Power in my car. The sticker on the cap asks for at least 98RON, and my mechanic who used to own one warned me off Tesco and Sainsburys, they don't have the same additives in them.
Still only doing 23mpg average.
ive filled up in Hereford, Richmond (London) and Colchester and it seems V-power is just around that price at the moment.
A higher octane rating means lower ignition temp.
I assume that one of the reasons you get more mpg is less fuel is unburnt as it doesn't need to get as hot to burn it all up.
Also they contain lubricants so the engine will run smoother, waste less energy as heat in the engine (from friction between pistons and engine), more as kinetic energy
At the moment I am doing short 5-10 mile trips in london, so will see what the mpg is like with that.
The fuel does nothing for the friction between the piston and cylinder.
Fuel of a higher octane rating burns more efficiently. That's not to say it burns better, more complete, and don't confuse efficiency with economy. Efficiency is the amount of kinetic energy produced for the amount of chemical energy used.
Premium fuel shows the best gains in cars that are turbocharged, and modern cars with knock sensors, which essentially a little microphone bolted to your engine block (or sometimes cylinder head) that listens for detonation ,and adjusts your spark timing to suit, to give optimum power.
Yes, I am not confusing the two, I am simply saying if there is a lower of ignition temp, chances are more of it will have burnt after a spark from the spark plug as more of it will have heated up to the ignition temperature before leaving the engine.
I would have thought this would happen at higher revs more than lower, as the fuel has less time in the cylinder to heat up when it is at 12k than when at 1k.
